Medion P10 Specialist (30034002) hot
4 ANTWORTEN 4
Renzor
Nachricht 1 von 5
1.521 Aufrufe
Nachricht 1 von 5
1.521 Aufrufe
Hi the above laptop is regularly hitting CPU temps of 100 degrees is this normal and/or ok? Thanks in advance. Renzor
4 ANTWORTEN 4
EastClintwood
Nachricht 2 von 5
1.459 Aufrufe
Nachricht 2 von 5
1.459 Aufrufe
Hello @Renzor, and welcome to the community.
In which applications do these temperatures occur?
Which settings have been changed?
It might be helpful to perform a PC performance test.
If you have any further questions, please feel free to contact me.
Greetings,
EastClintwood
Renzor
Nachricht 3 von 5
1.452 Aufrufe
Nachricht 3 von 5
1.452 Aufrufe
apologies for the late response. This occurs when gaming, no settings have been changed, I use the performance profile in the Medion software for fan control. The laptop doesnt crash I just dont want to be doing damage to it.
Cheers Renzor
EastClintwood
Nachricht 4 von 5
1.445 Aufrufe
Nachricht 4 von 5
1.445 Aufrufe
Hello @Renzor,
The CPU of your notebook is designed for temperatures up to 100C. If you don't need the full performance for these games and you don't feel comfortable with these temperatures, I would first recommend you to test another mode (Eco) to see if lower temperatures can be achieved with the same performance.
Regards,
EastClintwood
Renzor
Nachricht 5 von 5
1.423 Aufrufe
Nachricht 5 von 5
1.423 Aufrufe
Thanks if they are designed to run at this temp then that's fine I just wanted to check 👍
4 ANTWORTEN 4
