Display blackouts and 10-bit color limitation at high refresh rates via TBT5 -ERAZER Beast 18 X1
0 REPLIES 0
Alex1389
Message 1 of 1
Message 1 of 1
ERAZER Beast 18 X1 (MD 62731) UK
MSN: 3003 9673
Serialnumber: 30039673SKU754W00165
Hello everyone,
I am experiencing technical issues with my external monitor connection and would appreciate some help.
My Setup:
  • Laptop: Medion Erazer Beast 18 x1 MSN: 3003 9673
  • Port: USB-C Thunderbolt 5 (TBT5 + DP1.4 dGPU + PD100W)
  • Monitor: MSI MAG 27CQ6F (WQHD, 180Hz, DP 1.4)
  • Cable: Ugreen USB-C to DisplayPort (Tested both 8K and 16K versions)
The Issues:
  1. Random Blackouts: The screen goes black for 2-3 seconds at random intervals, both during gaming and desktop use.
  2. Color Depth Limitation: I am unable to select 10-bit color depth if the refresh rate is set higher than 120Hz. When I try to go to 144Hz or 180Hz, the system forces 8-bit color or the signal becomes extremely unstable.
Technical Questions:
  • Is the DP 1.4 implementation on this TBT5 port limited in bandwidth, or is this a DSC (Display Stream Compression) handshake issue?
  • Since the port is routed through the dGPU, is there a specific VBIOS or Firmware update to stabilize high-bandwidth signals (WQHD @ 180Hz + 10-bit)?
  • Could the PD100W feature be causing electrical interference with the DisplayPort signal on the same port?
I have already tried updating NVIDIA drivers and using different high-quality cables, but the problem persists.
Thank you in advance for any advice!
0 REPLIES 0
0 REPLIES 0
