MEDION® LifeCloud® P89654 (MD 90224) RAID Drive Failure
2 ANTWORTEN 2
filipe
Nachricht 1 von 3
3.844 Aufrufe
Nachricht 1 von 3
3.844 Aufrufe
Hello dear members of the MEDION community!
A few days ago I received an e-mail from my NAS P89654 (MD 90224) with the following message:
A failure was detected on your MEDION® LifeCloud® RAID Array.
Please visit the Preferences section.
Actually only one of the two Toshiba hard drives was detected in the settings. After a reboot, the faulty hard drive will be detected again and during the RAID I recovery process, the faulty hard drive will eventually disappear from the Disk Management and only the working hard drive will be detected.
Before the healthy hard disk also stops working, I wanted to replace the defective hard disk with a new identical Toshiba MD04ACA400.
Before I order and install a new hard disk, is there anything I should consider?
1. doesn't the hard disk need to be formatted to be recognized?
2. how do I recognize in the rack which hard disk is N°1 and which is N°2? According to the LED (second LED is red) the hard disk N°2 should be defective.
Thanks in advance for any help, because I have checked all forums and found no thread which could fit my problem.
Lolopadepo
Nachricht 2 von 3
3.697 Aufrufe
Nachricht 2 von 3
3.697 Aufrufe
Salut filipe,
You'll find below the picture that will allows you to identify the defective HDD regarding the RED led:
Identification HDDIdentification HDD
We recommend you to contact a specialist to replace the defective HDD as we do not ensure the lose of data in that case.
Lolopadepo
2 ANTWORTEN 2
Lolopadepo
Nachricht 2 von 3
3.698 Aufrufe
Nachricht 2 von 3
3.698 Aufrufe
Salut filipe,
Lolopadepo
filipe
Nachricht 3 von 3
3.674 Aufrufe
Nachricht 3 von 3
3.674 Aufrufe
Thanks a lot Lolopadepo! 😄
I managed to swap the defective HDD by a new one and the RAID1 rebuild is being completed thanks to your contribution!
Kind regards,
Filipe
2 ANTWORTEN 2
