Medion HD Drive 2 GO
1 RÉPONSE 1
PeWi
Message 1 sur 2
2 756 Visites
Message 1 sur 2
2 756 Visites
Hello,
I have a Medion HD Drive 2 GO.
But after a break in at home, the burglar stole our laptop and tried to steal our HD also.
He did take the adapter from the HD Drive and now we are searching for a replacement.
Spec's: MD 90132.08
KSAD1200150W1EU power supply, 12V 1,5 a
Who can help us!
Thanks!
1 RÉPONSE 1
REV
Moderator Moderator
Message 2 sur 2
2 701 Visites
Message 2 sur 2
2 701 Visites
Hello @PeWi
Unfortunately, Medion no longer has these in stock. We can only advise you to look for an adapter that meets the following specifications:
Input voltage 100 ~ 240 Volt
Input frequency 50 ~ 60 Hz
Input power 0.4 Ampere
Output voltage 12 Volt
Output power 1.5 Ampere
Plus Inner pole
Minus Outer pole
Kind regards,
REV
1 RÉPONSE 1
