46153members
320online
158119posts
The slot bracket (also called slot cover) is an elongated piece of sheet metal or plastic that serves to cover gaps in the rear of computer housings. It is simply clipped into the inside of the enclosure, easily broken out in the case of disposable panels, or fastened with screws.
