solution to stop ventilation?
4 RÉPONSES 4
Nomi613
Message 1 sur 5
1 430 Visites
Message 1 sur 5
1 430 Visites
Hello everyone,
I've just bought a Medion Erazer Deputy P40 which I find extra except for one thing, this ventilation that declenches at 25% above 40 ° C,
is it possible to change that?
The computer doesn't heat up at all, it would be great to be able to change this to 15/20% or switch it off after 50°C.
I should point out that I was able to take all the information about the fan speed from the Control Center Package application.
thank you
4 RÉPONSES 4
Wannaou
Message 2 sur 5
1 381 Visites
Message 2 sur 5
1 381 Visites
Hello, try to install Fan Speed Setting from Microsoft store trough you can set all fans (cpu-gpu).
Nomi613
Message 3 sur 5
1 368 Visites
Message 3 sur 5
1 368 Visites
Thanks, I've just tried it, same problem, it's 25% minimum 😞
Wannaou
Message 4 sur 5
1 364 Visites
Message 4 sur 5
1 364 Visites
it means the your laptop have to work in that way. I have a crawler e30 and its fans run 28%, aways.
Nomi613
Message 5 sur 5
1 348 Visites
Message 5 sur 5
1 348 Visites
it's a shame... I hope Medion will fix it, it's really annoying, I've limited the power consumption of my processor, it doesn't heat up at all, I'd have liked it if the fans could have been turned off or simply slowed down even more
4 RÉPONSES 4
