am 16.11.2023 20:33
am 16.11.2023 20:33
The computer doesn't heat up at all, it would be great to be able to change this to 15/20% or switch it off after 50°C.
I should point out that I was able to take all the information about the fan speed from the Control Center Package application.
thank you
am 22.11.2023 16:48
am 22.11.2023 16:48
Hello, try to install Fan Speed Setting from Microsoft store trough you can set all fans (cpu-gpu).
am 23.11.2023 00:30
am 23.11.2023 00:30
Thanks, I've just tried it, same problem, it's 25% minimum 😞
am 23.11.2023 08:44
am 23.11.2023 08:44
it means the your laptop have to work in that way. I have a crawler e30 and its fans run 28%, aways.
am 24.11.2023 02:28
am 24.11.2023 02:28
it's a shame... I hope Medion will fix it, it's really annoying, I've limited the power consumption of my processor, it doesn't heat up at all, I'd have liked it if the fans could have been turned off or simply slowed down even more
