Water Cooling Kit - Erazer Beasr X40
41 ANTWOORDEN 41
SiaOiz
Bericht 1 van 42
20.386 Weergaven
Bericht 1 van 42
20.386 Weergaven
Hi all,
I have the Erazer Beast X40 and just trying to find out where I can buy the Water Cooling Kit for this laptop from?
Thanks
Matt
41 ANTWOORDEN 41
Thenewb
Bericht 31 van 42
3.291 Weergaven
Bericht 31 van 42
3.291 Weergaven
I'm in exactly the same boat and it doesn't appear you can buy it anywhere in the UK or from the German store anymore, they seem to have sold out of the stock of 10 they had in the warehouse
Thenewb
Bericht 32 van 42
3.290 Weergaven
Bericht 32 van 42
3.290 Weergaven
Did you find out if it was compatable
Mrdanky
Bericht 33 van 42
3.278 Weergaven
Bericht 33 van 42
3.278 Weergaven
Xmg oasis works fine. I have a medion one that I don’t use if you wanted to keep the medion bios and control centre you can buy it. If not just buy the oasis and flash their bios, it’s better anyway.
Odarnok
Bericht 34 van 42
3.271 Weergaven
Bericht 34 van 42
3.271 Weergaven
XMG bios is a beast, transform the laptop in a powerhouse
https://www.3dmark.com/spy/40196886
The issue is that you must buy XMG water cooling kit (Oasis 2023) if you want better temps... but is a fair deal.
Mrdanky
Bericht 35 van 42
3.260 Weergaven
Bericht 35 van 42
3.260 Weergaven
Great score! Could maybe even push higher on gpu but bit tricky in summer unless you have ac.
also you can use medion watercooler with xmg bios, works fine for me
Odarnok
Bericht 36 van 42
3.256 Weergaven
Bericht 36 van 42
3.256 Weergaven
Laptop with air cooling, ambient temp 25º C (40ºC in my city) Modern air conditioner is a great, magnificent, magical, plus ultra invention.
I bought XMG Oasis 2023 because I wanted reward Shenker for their support despite i have other brand laptop.
And it's impossible buy Medion's water cooling kit.
Thenewb
Bericht 37 van 42
3.247 Weergaven
Bericht 37 van 42
3.247 Weergaven
What's the bios that I need, do you have a link?
Odarnok
Bericht 38 van 42
3.243 Weergaven
Bericht 38 van 42
3.243 Weergaven
It remains under your full responsibility what happens. I preferred to take the risk, but you should know that with this you can lose the official manufacturer's guarantee, Medion. Choose your version well and review how to install the bios.
https://download.schenker-tech.de/package/xmg-neo-16-17-e23-xne16e23-xne17e23/
I did it over version 1.20-1.07 of Medion, if I remember correctly and everything went the first time. If you prefer use first Medion, take it
https://cdn.medion.com/downloads/software/00_Bios_Beast_X40.zip
Odarnok
Bericht 39 van 42
3.211 Weergaven
Bericht 39 van 42
3.211 Weergaven
Better temps under max load, performace similar.
Aida64 cpu and memory stress test: from 8% cpu throttling after 10 minutes (97ºC hottest core) to 0% cpu throttling after 40 minutes (88ºC hottest core).
Sid Meier's Civ VI, all DLCs and many user mods, from 95ºC in CPU to 83ºC, GPU from 80ºC to 70ºC, after 60 minutes, first with gsync (240 fps), second without (450 fps).
Odarnok
Bericht 40 van 42
3.197 Weergaven
Bericht 40 van 42
3.197 Weergaven
Sorry, a change (for better)
Previous tests were at 30ºC, with air conditioner (25ºC), 5 to 10 degrees less.
41 ANTWOORDEN 41
