Question regarding BIOS and motherboard compatibility (B660H7-M20) (Medion Erazer Recon P20)
2 RÉPONSES 2
startledsnake
Message 1 sur 3
1 908 Visites
Message 1 sur 3
1 908 Visites
I have a Medion Erazer Recon P20 (msn 10024815) running version BIOS Version B660H7W0X.107 (Release Date 23/02/2022) on a B660H7-M20 motherboard.
My question is surrounding two things. First is if there is a way to enable XMP Profile on this motherboard with a BIOS update or such, as I had bought 32gb 3200 mhz ram, but because it is not currently available in BIOS, it defaults to 2133 mhz. Is there any solutions, or is it pure BIOS/Motherboard limitation?
Also, I am currently trying to install a PCIE wifi adapter (tp-link tx3000e), however my system is in no way picking it up, even though i have the wifi drivers, and I installed the wifi card in the correct slot, unless i am wrong. I attached an image of the motherboard with the slot i am talking about.
1 SOLUTION APPROUVÉE
Solutions acceptées
Vince
Message 2 sur 3
1 878 Visites
Message 2 sur 3
1 878 Visites
Hello,
you can't RAM with XMP and 1,35V. Only RAM 3200MHz with 1,2V!
Newer BIOS v1.112 for your Mainboard
2 RÉPONSES 2
Vince
Message 2 sur 3
1 879 Visites
Message 2 sur 3
1 879 Visites
Hello,
Vince
Message 3 sur 3
1 876 Visites
Message 3 sur 3
1 876 Visites
Your Mainboard have M.2 Slot for WiFi/BT. You can install your WiFi-Modul from your Card.
Here Manual for your motherboard
https://www.ecs.com.tw/de/Product/Motherboard/B660H7-M20/download
2 RÉPONSES 2
