on 03.01.2019 14:38
on 03.01.2019 14:38
i tried to update my pc and got a driver update wich i think was bad , after i run bios update (bioe642x_p666x.exe) my laptop rebooted and i got a black screen.
now i dont know what to do or how to restore the old bios , anythink i do or press wont start my laptop display , the laptop starts.
Any idea how to fix this ?
Thanks
03.01.2019 18:48 - edited 03.01.2019 20:18
I try to help you - if you are lucky it works again
Bios-Reset
Removing the power source will completely reset your BIOS to factory defaults.
Look for a yellow CMOS battery on the motherboard and remove it. Also remove the battery connection
Wait up to 20 minutes after the BIOS has forgotten all settings made.
The waiting time is necessary because the settings without battery for residual current discharge.
This restores the original configuration. Then press and hold the power button for 20 seconds for residual current discharge when the batteries are disconnected
Gruß Raymond
