Medion Erazer Deputy P10 BIOS Update
6 REPLIES 6
ADooley8
Message 1 of 7
Message 1 of 7
Hey guys,
Curious question. I have a deputy P10 with a GTX 1660ti and an i5-10300h, MSN: 30029473. Love the laptop, not the temperatures. The CPU hits 100c while gaming.I've tried undervolting but to no success. Does anyone have a BIOS update that may help? current on version 2.11 and wondering if a new version would help? or if anyone else has other help would really appreciate it!
Mnay thanks,
Adam
6 REPLIES 6
mats749
Message 2 of 7
Message 2 of 7
Hi @ADooley8
Welcome to the community!
100c is a little on high side, so I'm assuming that you're seeing thermal throttling. Can you hear the fans running?
Thanks
Mats749
ADooley8
Message 3 of 7
Message 3 of 7
Hey thanks for the reply! Yeah it throttles alright, hits about 3.7/3.8ghz when it hits that temp, which I still think is very high….fans are at 100% at that temperature so nothing I can do there. Any help is appreciated!
mats749
Message 4 of 7
Message 4 of 7
@ADooley8,
In this instance id recommend that you contact your local medion service center for a potential warranty solution.
Thanks
Mats749
ADooley8
Message 5 of 7
Message 5 of 7
Hey,
without sounding smart, what could they do for me if I sent it back for warranty? I had presumed it was just the design of the laptop, or am I wrong?
mats749
Message 6 of 7
Message 6 of 7
@ADooley8
Sorry, let me expand my last,
The temperature is dependent on a lot of variables including environmental, type of load etc.
While temps of 100c are not unheard of while under high load, perhaps there are certain other factors that could be changed to improve the heat dispersion such as repasting the CPU, cooling stands, dusting etc.
The warranty solution was pointing towards the repasting of the CPU if required. Depending on how old the laptop is of course.
Thanks
Mats749
ADooley8
Message 7 of 7
Message 7 of 7
Thanks for expanding! The laptop is only a year old so it really shouldn’t be the paste, so I feel I can write that one off the list, so maybe I’ll just have to look at adjusting clocks and trying to keep it well ventilated
6 REPLIES 6
