MEDION ERAZER X7853 camera issue
5 REPLIES 5
RobM-UK
Message 1 of 6
Message 1 of 6
Hi All,
First post, I have purchased MSN: 3002 2560 in 2018 and I am happy with it, I do have an issue with the onboard camera. While I could see it in device management showing as "Chicony USB 2.0 Camera" in windows camera app was not seeing it, I have gone through all the camera settings and tried turning everything on relating to camera and apps using camera. I tried uninstalling the camera and drivers, then check for hardware changes but nothing is showing up.
Launched microsoft team and it's not detecting a camera. Next I run the diagnostic app and it reports no issues however, there is no camera check done or option to do a custom check where I can test camera. Windows is up to date. I am asking if anyone can assist me please.
Many Thanks
Rob
5 REPLIES 5
Message 2 of 6
Message 2 of 6
@RobM-UK
Is the camera listed in device manager?
Did you switch the camera on? There is a on-off switch for the camera, you know?
---> Manual  Page 27/ 28
Bye, daddle
RobM-UK
Message 3 of 6
Message 3 of 6
@daddle  for some reason at the time I could not get it to work even though I was using the fn and camera button on F key as I noted on manual. Yesterday I was working. hmmmmmm Could be user error of some kind. It is now working perfectly. Thank you.
Message 4 of 6
Message 4 of 6
@RobM-UK
I do not understand. So the cam did work, or not?
RobM-UK
Message 5 of 6
Message 5 of 6
This is the thing, I could not get it to work prior to my post. I left it off for few days and when I rebooted I found it working perfectly and being able to switch it off/on. So no idea what happened. All I can say it's working.
Message 6 of 6
Message 6 of 6
@RobM-UK
The full Reboot after happened, I guess.
Much pleasure with it. It's always nice if things do work.
Regards, daddle
5 REPLIES 5
