How to open the panel of Deputy P30?
2 REPLIES 2
nk77
Message 1 of 3
Message 1 of 3
Hi all,
Is there anyone who can tell me how to approach to the RAM slots in Deputy P30?
I see that there are screws but it does not seem that I can open the panel even after I remove the screws..
Best
2 REPLIES 2
EastClintwood
Message 2 of 3
Message 2 of 3
Hello @nk77, and welcome to the community.
In addition to the screws, clips can also be used for fastening.
Take a card and carefully go through the slot so as not to break off the clips but to loosen them.
Greetings,
EastClintwood
nk77
Message 3 of 3
Message 3 of 3
Hi @EastClintwood ,
Thank you very much for your input.
It is difficult for me to find the gap between the main body and the bottom panel.
Do you think that someone has a picture which tells me where it is?
Best regards,
Noriyuki
2 REPLIES 2
