on 11.05.2021 12:15
on 11.05.2021 12:15
Hello,
I've recently purchased a gaming desktop from Medion (ERAZER ENGINEER P10 MD35007). There is some unbearable loud and noise (although it sounds functional) coming from the back of it when the GPU is under load. I can't determine for sure if it comes from the Power Supply or from the Fan(with blue led) just underneath it. So far I'd say 60% chance from the power supply.
I reduced the fans(with blue leds) rotation to 600-700 rpm wih the help of Bios modifications and a software but it doesn't fix the issue at all.
i really don't want to send the tower back since I like the components and design and I don't want to wait 3 weeks for a refund (just sent back another desktop last month because the GPU didn't matched the description).
So what are my options and what could Medion do to help ?
Should I change the fans and if it doesn't solve the issue, change the power supply ?
What do you think ?
on 16.03.2022 09:14
on 16.03.2022 09:14
I have the same problem, is this actually dangerous or is it just annoying. Can i ignore it?
on 16.03.2022 09:31
on 16.03.2022 09:31
For me it was faulty MB and it tried to get out maximum of PSU and after couple of days it destroyed CPU, SSD and MB it self most likely due to overvoltage.
on 16.03.2022 09:34
on 16.03.2022 09:34
I returned the computer and got a new one of the same make and model, but its still making the same noise when it heats up. I dont think its a faulty component, but i also dont know what else it could be
on 16.03.2022 09:38
on 16.03.2022 09:38
Were you able to use the pc like normal ignoring the sound or did something happen after?
on 16.03.2022 09:39
on 16.03.2022 09:39
Im just sharing my experience. I got new PC for 2 weeks. I played Warzone and under load PSU worked on full speed. Then one day it just stopped working. I returnet it to warranty and guys. Replaced MB, CPU and SSD cuz they were dead. And after there was no problems at all. It was a bit loud under load but not that it was before. Try to buy Corsair RM650X and you will not hear it at all 👍🏼
