MD19900 Does not vacuum
1 ANTWOORD 1
Zelupi
Bericht 1 van 2
1.047 Weergaven
Bericht 1 van 2
1.047 Weergaven
Hi,
my MD19900 does not vacuum, it just walks around without turning on the vacuum engine, sit someone have the same issue?
Can someone helps how to fix this?
Best regards
1 ANTWOORD 1
Mallia
Bericht 2 van 2
1.014 Weergaven
Bericht 2 van 2
1.014 Weergaven
@Zelupi Sorry to see that you are experiencing this issue.
If the product turns on but no vacuum suction, please check the roller brush under the product for any stuck debris.
If the vacuum motor is not turning on you may wish to consider contacting your local Medion support team for further assistance. https://www.medion.com/gb/service/
1 ANTWOORD 1
