please help , recovery partition incorrect
3 ANTWORTEN 3
colts18
Nachricht 1 von 4
4.214 Aufrufe
Nachricht 1 von 4
4.214 Aufrufe
hi I have old medion akoya e4110 D (MD 8239), Model: MT22 , MSN: 10019140. I have all recovery disc (2 disc) , USB recovery disc (cyberlink powerrecover) and medion recovery folder inside: esp.wim , install.wim , winre.wim , etc... , I try to restore medion to factory default (windows 8.1) but always error it say program cannot restore because system partition structure is incorrect.  please I need help ,please? thank you.
3 ANTWORTEN 3
EastClintwood
Nachricht 2 von 4
4.204 Aufrufe
Nachricht 2 von 4
4.204 Aufrufe
Hello @colts18, and welcome to the community.
Repairing the partition table via the command prompt:
If the Windows installation CD or DVD is available, you can use it to access Command Prompt to repair the corrupted partition table in Windows 11/10/8/7.
Step 1. insert the installation disc, restart your computer and boot from the disc.
Step 2. After booting your system, start the command prompt.
In Windows 8/8.1/10 and Windows 11, from the Welcome screen, click Repair Computer>Troubleshooting>Command Prompt.
Step 3. When the Command Prompt has loaded successfully, run the following two commands:
▶bootrec /FixMbr
▶bootrec /FixBoot
If this does not solve the problem, feel free to inform us and send us a screenshot of your error message.
Regards,
EastClintwood
colts18
Nachricht 3 von 4
4.181 Aufrufe
Nachricht 3 von 4
4.181 Aufrufe
Hi @EastClintwood, I appreciate you for answering but unfortunately this has not solved my issue, PowerRecover still says that the system partition structure is incorrect. Attached below are screenshots of the issue.
jacobz
Nachricht 4 von 4
2.248 Aufrufe
Nachricht 4 von 4
2.248 Aufrufe
Hi,
Did you ever manage to fix this? I have the same issue. I can boot into the PowerRecovery partition, but get the same message. Also, my F11 splash screen is gone. This happed after I tried to install another OS, but I did keep the recovery partitions.
3 ANTWORTEN 3
