Upgrade of Medion Akoya p5360e with graphic card possible?
16 ANTWORTEN 16
cojes
Nachricht 1 von 17
14.708 Aufrufe
Nachricht 1 von 17
14.708 Aufrufe
Hello everybody,
with which graphic cards I can upgrade my Medion Akoya p5360e. I have already tried four different allegedly compatible graphic cards from AMD and Nvidia, but always beeps the motherboard 5 times.
-The board is a MEDION H110H4-EM with BIOS UEFI 110EMW0X.103 (Chipset: Intel H110 (Skylake PCH-H).
-Built-in original card is a RX 460 2GB, Video BIOS version: 015.050.000.000.016258.
Although it worked with a GTX 1050Ti to start, so I had a picture, but it also beeped always 5 times and the card had always picture dropouts.
Is the board absolutely incompatible for other graphics cards?
Thanks and regards
16 ANTWORTEN 16
cojes
Nachricht 11 von 17
5.655 Aufrufe
Nachricht 11 von 17
5.655 Aufrufe
no problems, it's a Sapphire AMD Radeon RX 570 Pulse 8GB. I have also upgraded CPU to
Intel I7 6700 3,40 GHz.
kuishi
Nachricht 12 von 17
5.652 Aufrufe
Nachricht 12 von 17
5.652 Aufrufe
but have you changed the alimentation ?
cojes
Nachricht 13 von 17
5.650 Aufrufe
Nachricht 13 von 17
5.650 Aufrufe
you mean the pc power supply? No, the 350W is ok
cojes
Nachricht 14 von 17
5.648 Aufrufe
Nachricht 14 von 17
5.648 Aufrufe
but you can use also the RX 570 4GB with only one fan. This card runs without 6-pin extra power supply.
kuishi
Nachricht 15 von 17
5.637 Aufrufe
Nachricht 15 von 17
5.637 Aufrufe
thanks sorry... i thought ( i m french ) alimentation was the same word in english and french 😕 ^^
in the rx570's spec is recommended 500w i m surprised pleasantly .
well, now, i hesitate with gtx 1060 ( but not sure for compatibility ^^ ... to be continued )
thanks a lot for your answers and informations
cojes
Nachricht 16 von 17
5.626 Aufrufe
Nachricht 16 von 17
5.626 Aufrufe
In this list you can check the power for most cards: https://www.pc-erfahrung.de/grafikkarte/vga-grafikrangliste.html
The RX 570 8GB is listed with 150W, and this is correct. The 1060 is listed with 120W, so I think the 350W power supply is also ok.
sebin3m
Nachricht 17 von 17
4.041 Aufrufe
Nachricht 17 von 17
4.041 Aufrufe
Hy, do you find a solution for your problem, thank you
16 ANTWORTEN 16
