Upgrade of Medion Akoya p5360e with graphic card possible?
16 RÉPONSES 16
cojes
Message 1 sur 17
17 085 Visites
Message 1 sur 17
17 085 Visites
Hello everybody,
with which graphic cards I can upgrade my Medion Akoya p5360e. I have already tried four different allegedly compatible graphic cards from AMD and Nvidia, but always beeps the motherboard 5 times.
-The board is a MEDION H110H4-EM with BIOS UEFI 110EMW0X.103 (Chipset: Intel H110 (Skylake PCH-H).
-Built-in original card is a RX 460 2GB, Video BIOS version: 015.050.000.000.016258.
Although it worked with a GTX 1050Ti to start, so I had a picture, but it also beeped always 5 times and the card had always picture dropouts.
Is the board absolutely incompatible for other graphics cards?
Thanks and regards
16 RÉPONSES 16
cojes
Message 11 sur 17
6 630 Visites
Message 11 sur 17
6 630 Visites
no problems, it's a Sapphire AMD Radeon RX 570 Pulse 8GB. I have also upgraded CPU to
Intel I7 6700 3,40 GHz.
kuishi
Message 12 sur 17
6 627 Visites
Message 12 sur 17
6 627 Visites
but have you changed the alimentation ?
cojes
Message 13 sur 17
6 625 Visites
Message 13 sur 17
6 625 Visites
you mean the pc power supply? No, the 350W is ok
cojes
Message 14 sur 17
6 623 Visites
Message 14 sur 17
6 623 Visites
but you can use also the RX 570 4GB with only one fan. This card runs without 6-pin extra power supply.
kuishi
Message 15 sur 17
6 612 Visites
Message 15 sur 17
6 612 Visites
thanks sorry... i thought ( i m french ) alimentation was the same word in english and french 😕 ^^
in the rx570's spec is recommended 500w i m surprised pleasantly .
well, now, i hesitate with gtx 1060 ( but not sure for compatibility ^^ ... to be continued )
thanks a lot for your answers and informations
cojes
Message 16 sur 17
6 601 Visites
Message 16 sur 17
6 601 Visites
In this list you can check the power for most cards: https://www.pc-erfahrung.de/grafikkarte/vga-grafikrangliste.html
The RX 570 8GB is listed with 150W, and this is correct. The 1060 is listed with 120W, so I think the 350W power supply is also ok.
sebin3m
Message 17 sur 17
5 016 Visites
Message 17 sur 17
5 016 Visites
Hy, do you find a solution for your problem, thank you
16 RÉPONSES 16
