P5018 D wont boot
1 ANTWOORD 1
Kev
Bericht 1 van 2
4.314 Weergaven
Bericht 1 van 2
4.314 Weergaven
P5018 D wont boot
Hey guys,
After upgrading the Ram in my P5018 D the unit will not boot, i've installed 16GB of ram, is this more then the mainboard can support or what could be the cause?
Grz. Kevin
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Murphy
Retired
Bericht 2 van 2
5.459 Weergaven
Bericht 2 van 2
5.459 Weergaven
@Kev - Good morning and welcome to the Community!
The Mainboard of your PC supports a maximum of 16 GB DDR3-SDRAM (PC3-12800 / 1600 MHz) Single Channel Memory.
If you use memory modules with these specifications there should be no problem.
VG,
Murphy
1 ANTWOORD 1
Murphy
Retired
Bericht 2 van 2
5.460 Weergaven
Bericht 2 van 2
5.460 Weergaven
VG,
Murphy
1 ANTWOORD 1
