MEDION Erazer Recon P25 (MD35174) randomly reboots
1 REPLY 1
MrPhilip
Message 1 of 2
Message 1 of 2
Hello,
I have this issue where my PC keeps randomly rebooting, either when I'm playing games, or if just left idle.
I've noticed similar posts in the ERAZER gaming section, all suggesting a BIOS update. Might be related?
My current BIOS version is 550A4W0X.214
Best regards,
Filipe
1 ACCEPTED SOLUTION
MrPhilip
Message 2 of 2
Message 2 of 2
Hello, problem solved!
If someone ends up having the same issue, the problem was the motherboard. It was not compatible with the other components (not sure if it was the GPU or CPU).
Anyway, replaced the motherboard for a new one and it is now working fine!
Best and good luck,
Filipe
1 REPLY 1
MrPhilip
Message 2 of 2
Message 2 of 2
Best and good luck,
Filipe
1 REPLY 1
