Fans are making noise
1 REPLY 1
Perryvdbosch
Message 1 of 2
Message 1 of 2
Hello,
The fans of my pc makes an awful lot of noise, I once clicked on optimise performance in the bios. Since then my fans have been making an awful lot of noise.
My PC is a MT39 MED MT 83337N, in it there is a BaseBoard Product B560M AORUS PRO AX with BIOS version 106
What can I do about this because this is driving me crazy.
1 REPLY 1
EastClintwood
Message 2 of 2
Message 2 of 2
Hello @Perryvdbosch,
Please tell us the MSN number of your PC.
Is it possible to undo the changed setting?
It should be possible to reduce the volume of the fans by making changes in the bios.
If you want to get the maximum performance out of your PC it is normal that the fans get louder.
Greetings,
EastClintwood
1 REPLY 1
