ECS H81H3-TI Information
36 ANTWORTEN 36
gnomKOLIN
Nachricht 1 von 37
47.051 Aufrufe
Nachricht 1 von 37
47.051 Aufrufe
Hello!
Im planning to build mini PC and i was looking for slim motherboard. Ive found interesting model ECS H81H3-TI, but there are  not much usefull information about it. There is no this model in a list on ECS website, so no specification. In this thread https://community.medion.com/t5/Desktop-PC-All-In-One/ECS-H81H3-TI/td-p/58726 people have discovered that this motherboard was installed into MEDION AKOYA P2021 D AIO pc, but still no information i need.
I know that this AIO goes with 150W AC adapter but no information about CPU tbp max support (will i7 with 65w tdp work on this motherboard?).
It seems motherboard has MXM slot. Looks like 3.0 or 3.1. A or B type and max tdp support still unknown. As unknown GPU support list (will any MXM 3 gpu work?).
I hope someone here can help me with my questions.
With respect
Nicolay
36 ANTWORTEN 36
gnomKOLIN
Nachricht 31 von 37
6.511 Aufrufe
Nachricht 31 von 37
6.511 Aufrufe
Hi, LordKadesh!
First of all you should check where exactley does problem exisits - in Mobo or in graphics card. Best way - try other working card in mobo and try other working mobo with graphics card.
According my experience  even with wrong  vbios card should be recognized by OS as pci-e device. If your card  is not recognized by Mobo at all I guess it has hardware issues.  But I could be wrong.
Standard MXM cards has their own vbios chip (as desktop cards). Best way to flash new vbios is to use programmer. I use cheap Ch341A from aliexpress. You should find compatible vbios dump file on TechPowerUp and just flash it to vbios chip.
By the way I cheked your photos, and didnt noticed your MXM card's cooler. Without cooling card can be damaged cause overheat.
avico
Nachricht 32 von 37
6.056 Aufrufe
Nachricht 32 von 37
6.056 Aufrufe
Hi there, I saw your post and I saw they delete your gmail drive file or link from the post. Please, could you send me it by mail to avico3@gmail.com, Thanks in advance.
gnomKOLIN
Nachricht 33 von 37
6.052 Aufrufe
Nachricht 33 von 37
6.052 Aufrufe
Heyho! I've sent you link to bios file
LordKadesh
Nachricht 34 von 37
6.047 Aufrufe
Nachricht 34 von 37
6.047 Aufrufe
 Hi Gnom. This is how look actually my system with my mxm GPU.
I don't continue with the ECS motherboard for my proyect anda try with de HP SLIM motherboards. ECS mb had lot of problems and incompatibilies, and finally stop working.
Now my PC has the USDT 800G1 HP motherboard, 16GB DDR3 1600Mhz, Xeon E3 1240 v3, MXM GTX 980M 8GB VRAM and x2 SSD 512GB.
Thanks for your help in my proyect.
gnomKOLIN
Nachricht 35 von 37
6.044 Aufrufe
Nachricht 35 von 37
6.044 Aufrufe
Hey!
Glad to hear you have progress with your project. You're welcom!
As I know 980m gpu eats aroung 100w. It is great that your new motherboard  can transfer such much power from DC input to MXM card 😃
May I ask you to describe what actualy happened with your H81H3-Ti motherboard? May be it could be repaired?
Maki1964
Nachricht 36 von 37
5.470 Aufrufe
Nachricht 36 von 37
5.470 Aufrufe
Hello Please can you send me the H81H3-TI bios. Thank you very much
marekgaszynski64@op.pl
avico
Nachricht 37 von 37
359 Aufrufe
Nachricht 37 von 37
359 Aufrufe
Please could you send it to me at avico@iesjuandelacierva.edu.es. Thanks in advance.
I only could find h81h3-ti2 file and i net h81h3-ti.
36 ANTWORTEN 36
