[Help] 10 band graphic EQ-- how does it work? What freq. to remove treble peak?
1 REPLY 1
WillowNest
Message 1 of 2
Message 1 of 2
Newbie here wondering how the graphic EQs work. in a 10 band consisting of 31, 63, 125, ... up to 4k, 8k, 16k, how do the ranges work? let's say the '31' slider was adjusted, which range of frequency was affected? From 0 hz to 31, or 0/31 to 63? Same question applies to the other sliders up to 16 kHz.
Also, what bands would need to be adjusted to remove certain peaks in treble? focusing particularly on toning down the harshness of, say, cymbals and bells as well as the airiness of vocals.
Would greatly appreciate info on this, thanks!
1 REPLY 1
Gehringer
Retired
Message 2 of 2
Message 2 of 2
Thread closed due to inactivity
1 REPLY 1
