E1239T Windows Bluescreen (Driver Overran Stack Buffer)
1 REPLY 1
kumpasagv
Message 1 of 2
Message 1 of 2
Hi guys. I have a tablet E1239T but, i havent keyboard. My tablet boot is crashed and now there is a blue screen loop (Driver Overran Stack Buffer). I'm trying new os installation but, I cant boot any boot device. SD card, and usb disks. This tablet has only one type c output. I try with type-c usb hub. However, it never sees any other device as bootable. Can you help with this issue? What should I do?
1 REPLY 1
alexbeen
Message 2 of 2
Message 2 of 2
If your E1239T tablet is stuck in a blue screen loop and cannot boot from external devices via a Type-C USB hub, try the following steps:
  1. Check Boot Order: Ensure your tablet's BIOS/UEFI settings are configured to boot from USB or SD card. Access these settings, if possible, and verify the boot order.
  2. Use a Different USB Hub: Some USB hubs may not support bootable devices. Try using a different Type-C to USB hub or a dock that is known to support booting.
  3. Verify Bootable Media: Make sure the USB or SD card you are using is properly formatted and has a bootable OS installation image. Test it on another device if possible.
1 REPLY 1
