Control planel not woring
2 REPLIES 2
canadan2018
Message 1 of 3
Message 1 of 3
So short of it is that I had to reinstall Windows and then reinstall all the stuff that's normally on the laptop however the control panel app installed but nothing works all power mods are blank Are i have the erazer beast x25 Ryzen 7 5800H and 3080 16GB with 32GB of ram please help as i would love to have the extra control back. please let me know if need more info.
Screenshot 2023-10-10 205001.pngScreenshot 2023-10-10 205123.pngthere more things I need other than the app
1 ACCEPTED SOLUTION
canadan2018
Message 3 of 3
Message 3 of 3
I ended up uninstalling the control panel and installing the utilities software first and the reinstalled the control panel and it worked thank you for reply.
2 REPLIES 2
Message 2 of 3
Message 2 of 3
Hi @canadan2018 ,
in your case it would be important to know the 8-digit MSN number (3003xxxx) which is printed on the lower housing of your laptop.
You then can search for approprtiate software on our MEDION service portal with this number.
=> Example: https://www.medion.com/gb/service/product-detail/30033306
Before installing the new ControlCenter software please ensure to have "ancients parts" of the application uninstalled completely
Cheers
canadan2018
Message 3 of 3
Message 3 of 3
2 REPLIES 2
