Difference E3215 und E3216?
2 REPLIES 2
vikado
Message 1 of 3
Message 1 of 3
What is the difference of E3215 and E3216?
Is the Display really different?
1 ACCEPTED SOLUTION
Message 2 of 3
Message 2 of 3
Hi @vikado and welcome to the MEDION Community,
E3215 & E3216 describe one and the same model series. They differ just in terms of the size of SSD, HDD & RAM. The used display panels are identical.
Cheers
2 REPLIES 2
Message 2 of 3
Message 2 of 3
Cheers
ifrown
Message 3 of 3
Message 3 of 3
This is not correct, it's exactly the opposite, RAM and SSD are the same, only the Screen is different between both models, the screen of the 3215 is a bit brighter, that's all as far as I know.
2 REPLIES 2
