I have downloaded my drivers and put them onto a drive but what do I do? (WiFi problem)
1 REPLY 1
Rkjr
Message 1 of 2
Message 1 of 2
Idk what to do next, it doesn't have an exe file to work with so I'm not sure
1 REPLY 1
RAZZ
Message 2 of 2
Message 2 of 2
Hi @Rkjr
Firstly what unit do you have, could you let us know the MSN?
Are you not able to connect a ethernet cable to the unit and update drivers that way?
What sort of drive have you downloaded drivers onto and from where?
What is the initial fault? no WIFI?
Thanks
1 REPLY 1
