FAQs on connecting a MEDION TV set to a soundbar
How do I connect via HDMI?
- Connect the HDMI cable to both your Soundbar and your MEDION TV. Make sure that you use the HDMI ARC connection on the TV. Once the connection is established, go to the settings in the menu of the TV set and from there to the Sound menu. Select HDMI ARC in the sound output. Next, it is necessary to activate the CEC function. To do this, also go to the settings in the TV menu, then select the device settings and then the item CEC.
How do I connect via AUX?
- Simply connect the Soundbar to the TV set via a 3.5 mm jack cable to the headphones or AUX connection. The sound is automatically played back by the Soundbar.
How do I connect via S/PDIF? (optical output)
- If your TV has an optical output, you can also use it to connect to your soundbar. Simply connect both devices with a so-called S/PDIF cable. No further settings are necessary. After the connection has been established, the sound is automatically played back by the Soundbar.
