Medion Erazer P7651 MD61016 Built In Microphone not working
2 RÉPONSES 2
wizwych
Message 1 sur 3
1 710 Visites
Message 1 sur 3
1 710 Visites
Hi guys and gals
new to the forums and hoping someone can assist me Im using window10 x64 on the Medion Erazer P7651 MD61016 when i try to record anything via the Record function in windows It just sounds like a Raining noise.
Things ive tried so far
1 = Device Manager uninstall/reinstall Microphone ( nothing happened still the same )
2  = Update the Realtek HD drivers ( Didn't do anything for mic but did improve speaker sound)
3 = Taskbar SOUND icon RECORDING set MICROPHONE to default and put MICROPHONE VOLUME to max and turned BOOST down to half
4 = Microphone Icon appears on TASKBAR when I go to Voice Recorder It records but not my voice just sounds like rain/static
Can anyone please advise on any more that I can try to get the microphone working..
2 RÉPONSES 2
Fox10
Message 2 sur 3
1 670 Visites
Message 2 sur 3
1 670 Visites
@wizwych
Hi, is it possible that there is pluged in a Headset or Headphones in the Headset Port at the PC.
Maybe that can be trigger the PC that there is pluged in a Mic and route the signal to the port and not to the built in Mic?
You can try remove all pluged in devices and than try a new record to proof that idea.
best regards Fox10
#Medion #Erazer #läuftbeimir
xl185uk
Message 3 sur 3
1 511 Visites
Message 3 sur 3
1 511 Visites
thank you for the instruction about unplugging headphones ,i couldnt get my microphone to work till i unplugged my head phones never realised this  was causing the problem .
2 RÉPONSES 2
