on 28.06.2021 20:22
on 28.06.2021 20:22
Hello,
I have bought a Medion MD31204 TV and I was wondering how I could change the audio settings to outup to S/PDIF. De settings in MENU seem limited:
Sound:
Furthermore I cannot select the other settings under Sound.
MENU->Settings seems to have no relevant sound options to me.
Please Help.
Thanks in advance!
on 29.06.2021 19:10
on 29.06.2021 19:10
Hello Daniel,
After further testing I came to the conclusing it is working. Thanks.
Digital audio output AUTO and by that the sound is playing on the TV itself and on the external speakers aswell.
I turned down the volume of the TV to 0 and now everything is working perfect.
Kind regards.
on 29.06.2021 11:16
on 29.06.2021 11:16
Hello @OutputOnTV ,
Normally it should be sufficient to set the digital audio output to AUTO.
Can you see that light is shining out of the SPDIF connector?
on 29.06.2021 19:10
on 29.06.2021 19:10
Hello Daniel,
Kind regards.
