Why is water running out of the tumble dryer?
Question
Answer
Check the following causes:
  • The condenser flow strainer may be clogged and cause water to leak from the machine. To remedy this, remove the dirt from the condenser. You will find a detailed description in the operating instructions.
  • The door seal may be dirty or have something stuck in it. Clean the seal and check for foreign objects that need to be removed.
  • The appliance must be in a straight position so that the door is flush with the appliance and then closes properly. First check with a spirit level whether the appliance is straight to the back / front and / or to the side. With the adjustable feet, you can compensate for unevenness of the floor and thus bring the appliance into "balance".
Version history
Last update:
‎13.05.2025 12:36
Updated by:
Labels (1)
Contributors
