MSN 20064583, 20064874
Supports Intel Core X-Serie processors for LGA2066 Socket.
There are 8 memory slots on the mainboard, each of which can hold 16 GB of RAM. The maximum capacity is therefore 128 GB.
| Module: | 288-Pin DIMM |
| Type: | SDRAM DDR4 |
| Clocking: | 4500(OC)/ 4400(OC)/ 4333(OC)/ 4266(OC)/ 4200(OC)/ 4133(OC)/ 4000(OC)/ 3866(OC)/ 3800(OC)/ 3733(OC)/ 3600(OC)/ 3466(OC)/ 3400(OC)/ 3333(OC)/ 3200(OC)/ 3000(OC)/ 2933(OC)/ 2800(OC)/ 2667/ 2400/ 2133 MHz |
| Voltage: | 1,2V |
| Special features: | no ECC-support |
⚠️Note⚠️ In the 32-bit editions of Windows operating systems, a maximum of approx. 3.2 GB memory is recognised. You can find more information on this on the Microsoft website.
| Slot | Connection | Dimensions | Key(s) | Comment |
| 1 | PCIe / SATA | 2242, 2260, 2280 | M key | RAID 0 and RAID 1 |
| 2 | PCIe / SATA | 2242, 2260, 2280, 22110 | M key | RAID 0 and RAID 1 |
⚠️Note⚠️ For the fastening you need a screw with a metric M2 thread and a length between 2.5 mm and 3.0 mm. The head should have a diameter of 4 mm to a maximum of 5 mm. If the screws are not available in local shops, you can find them in online shops.
The front PIN assignment can be taken from the illustration.
Article in other languages:
Review Date: 2025-03-13
