45213members
9188online
155997posts
How can I make a recording with the MEDION LIFE E69143 (MD 43142) record and cassette digitizer?
Before you start recording, insert your desired storage medium (USB stick or SD card) and put on the record.
Proceed as follows:
FUNCTION button until the PHON mode appears in the display.REC / DEL button.⏮ ⏭ buttons and then confirm with REC / DEL.⏮ ⏭ which storage medium the recording is to be made on.MODE / CLOCK button.REC / DEL button twice. REC disappears from the display and END is shown.
⚠️Note⚠️ When a record side has run out and the turntable is at rest, pressing REC / DEL once is sufficient to end the recording.
Article in other languages:
Review Date: 2024-04-19
