USB Disk (setup as internal storage) Not Present at Power On of Android TV MEDION X14339 (MD30059)
1 REPLY 1
XPloRR
Message 1 of 2
Message 1 of 2
I have a MEDION X14339 (MD30059) Android TV.
I have a permanent Lexar USB microsd drive of 128GB inserted in the upper USB slot.
The USB Disk is formatted as internal storage.
When I start the TV from sleep, I always get an annoying notification that the USB is not connected.
I guess the system did not wait until the USB was powered up.
After 5 seconds the message disappears and the disk is present.
How can I disable this notification at power on (from sleep)?
1 REPLY 1
Mastermind
Message 2 of 2
Message 2 of 2
Hi @XPloRR ,
we had things checked in our tech dept. and unfortunaly as a matter of fact it unfortunately is not possible to prevent the TV from giving the failure notice at the startup.
Cheers
1 REPLY 1
