Smart full HD tv EPG freezing
2 ANTWOORDEN 2
bentley
Bericht 1 van 3
3.337 Weergaven
Bericht 1 van 3
3.337 Weergaven
I have a 39" Smart full HD TV and the EPG keeps freezing. The only way out is to exit then start again. It seems that if you track down more than 15 or so channels then it freezes.
Also, 3 times when I have first switched the tv on, there is a message that there is no signal and to first time install to rectify. Only had the tv since mid February so loosing confidence in it. The MSN is 30028449. Does anyone have any ideas or is this a return to supplier?
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
bentley
Bericht 3 van 3
3.241 Weergaven
Bericht 3 van 3
3.241 Weergaven
@Hi Gehringer
Thank you for your reply. Yes all leads/connetions ok and digital aerial works fine with other TV's.
Medion have identified this issue as a fault and the tv was replaced today.
Regards
2 ANTWOORDEN 2
Gehringer
Retired
Bericht 2 van 3
3.251 Weergaven
Bericht 2 van 3
3.251 Weergaven
Hi @bentley and welcome to the forum.
Are you using an aerial or an external box?
Also, can please you check that the cables are properly connected on their respective ports
Regards,
Gehringer
bentley
Bericht 3 van 3
3.242 Weergaven
Bericht 3 van 3
3.242 Weergaven
@Hi Gehringer
Regards
2 ANTWOORDEN 2
