on 04.04.2020 18:53
on 04.04.2020 18:53
Hi
When you manually configure the network settings on the Medion 55" TV (Aldi), there is the option of 2 DNS settings. If you enter 2 DNS servers manually, click SAVE and exit, upon viewing the settings again, DNS server 2 always reverts to 000.000.000.000. It will never save the 2nd DNS server IP address.
Has anyone else found this bug?
Cheers
on 05.08.2020 15:42
on 08.08.2020 16:00
on 08.08.2020 16:00
Hi
Unfortunately it doesn't work correctly with 1 DNS. I use a smart DNS solution to redirect Netflix to various countries. It requires 2 DNS servers for full functionality.
on 11.08.2020 12:12
on 12.08.2020 13:18
on 12.08.2020 13:18
Hi
That's correct, DNS 1 is set to UK and DNS 2 should be set to USA. This then allows the correct routing depending on the Netflix or other service location setting.
on 12.08.2020 15:24
on 17.08.2020 13:51
on 17.08.2020 13:51
Hi
We do own Panasonic and Hitachi 4K televisions and these are able to support 2 DNS addresses using different countries. It's only the Medion that seems to have this issue.
This TV seems to have a number of little issues unfortunately. Hopefully there will be further firmware updates to address these.
on 24.08.2020 09:33
on 24.08.2020 09:33
Hi @wackyraces ,
my advice for you at the moment is to try to use the automatic DNS configuration, which should detect both DNS servers if they are set up properly.
Regards,
Gehringer
