Medion Lifesmart P85251
1 REPLY 1
zorica
Message 1 of 2
Message 1 of 2
Hi
I bought Lifesmart Tv P85251.
I connected it to tv via hdmi, use attached  adapter to power it up.
When i start it up, i get error maingui stopped. How can i get pass this error, so i can use my device
1 REPLY 1
Message 2 of 2
Message 2 of 2
@zorica
This appliance is about 10 years old. I guess it's a defect in the electronic.
 This error message appears on the TV screen? All settings (source, audio ) are correcct? Your TV must be old too, if you wanna make use of a Smart settop box? Is there an HDMI ARC connection? Did you switch CEC on or off?
May be your HDMI cable is the same old?
cheers, daddle
1 REPLY 1
