on 03.08.2021 15:50
on 03.08.2021 15:50
Hi All,
Hopefully someone can help me solve this.
All of a sudden my TV has become stuck in a boot loop and keeps restarting whenever it is connected to the internet.
When connected by Wi-Fi the boot loop continues until the TV seems to disconnect itself from the Wi-Fi, when connected by Ethernet cable it continues until the cable has been removed from the TV.
I have gone through the First time installation again to see if this could fix the error but it still happens after connecting to the internet
There are no issues with the internet as it is working fine for phone, laptop, Xbox etc. I have even tried using a 4G hub from a different internet provider and the same issue occurs.
I’m wondering if maybe it needs a software upgrade but I cannot carry this out through the internet on the TV at the moment
MSN: 30028460
Software: V.5.28.7.4 MED
Application Version: V.4.18.0.6
Thanks
on 03.08.2021 18:01
on 03.08.2021 18:01
@Chelsea1604 Sorry for the follow up message but this forum doesn’t allow posts to be edited.
You will need to reset the wifi on the tv, not on Sky Q 👍
on 03.08.2021 18:07
on 03.08.2021 18:07
Medion’s ears must’ve been burning as they’ve literally just emailed me 😅
This is what they said:
Thank you for contacting us.
I apologise for the inconvenience caused. It appears that due to a Firmware update we have been experiencing this issue with our larger TV Models.
If you are able to turn your TV on, please go to the settings menu and disconnect all Wi-Fi/internet connections. Once this has been done, please perform a first time installation skipping the Wi-Fi/internet connection step and leaving it disconnected.
If you are unable to turn the TV on or it does not stay on long enough to access the menu screen, please turn off your Wi-Fi/internet router then proceed with the first time installation step above. Once completed ensure the TV is not connected to the Wi-Fi/internet and turn your router back on.
We are expecting a Firmware update shortly and we will be in contact to fully resolve this issue. In the meantime, it is also worth doing a static discharge of the TV as well if the above has not resolved the issue.
1. Turn off the TV.
2. Unplug all the cables from the TV
3. Please leave for 15 seconds
4. Press and hold the power button for 20 seconds (with the remote also) and then release it to drain the flea power (static charge.)
5. Reconnect all cables back again and turn on the tv.
6. Go to the setup menu and follow first time installation.
I hope this helps, if you are still having issues please can you reply to this e-mail with the following:
- the serial number of the TV
- an image of the whole TV screen
- the proof of purchase for the TV
Many thanks
If you require any further assistance then please do contact us.
Kind regards
So they’ve admitted it’s an update fault on their side and there’s no immediate fix but, as we’ve already discovered, disconnecting from the internet is the interim solution. Let’s hope they have a proper update soon 🤞
on 03.08.2021 18:07
on 03.08.2021 18:07
Two more people have posted about the issue in another thread group so definitely seems to be an update issue, too much of a coincidence for the same thing to happen to us all!
on 03.08.2021 18:10
on 03.08.2021 18:11
on 03.08.2021 18:15
on 03.08.2021 18:15
Mine does exactly the same, was working fine this morning, when I came home this afternoon it started rebooting. Through process of elimination I have found its the direct internet connection to TV. If I disconnect the cable / disable WiFi ,it works perfectly.
on 03.08.2021 18:21
on 03.08.2021 18:21
I was doing everything I could think of, plugging in different plug sockets, having nothing else plugged in then only certain things plugged in trying to eliminate it before I got to the conclusion it was the Internet, took me longer than it should have haha!
03.08.2021 18:29 - edited 03.08.2021 18:32
Thanks for this
After following the above advice
For any one who only watches the apps - if you have a phone or Laptop thats is connected to wifi you can do a wireless display if you put on Netflix or Youtube on your device:) just done it and I can watch youtube from my phone which is showing on the TV
You can select Wireless Device on Sources in the menu
on 03.08.2021 19:12
on 03.08.2021 19:43
on 03.08.2021 19:43
Yes 👍 I noticed it only works if you have an Android or Apple TV
Subject | Author | Posted | |
12.02.2022 13:06 | |||
11.10.2021 10:56 | |||
26.09.2020 18:40 | |||
22.10.2024 23:51 |
