Erazer x25 3070 model. USB-C to display port possible?
1 REPLY 1
kfoxszn
Message 1 of 2
Message 1 of 2
Hi I'm looking at buying the LG 34GP950G and I'm wondering what the best method of connecting it to this laptop would be?
HDMI 2.0 port won't be able to achieve 144hz at 2k.
Is it possible to use a usb-c to display port adapter with this device?
1 ACCEPTED SOLUTION
Message 2 of 2
Message 2 of 2
Hello @kfoxszn and welcome
Beast X25? please state the MSN number
if it is one:
on the back you have one:
1 x USB 3.2 Gen 2 Type-C (DP) Display Port-Funktion
You can connect it there with the appropriate adapter
bye Fishtown
1 REPLY 1
Message 2 of 2
Message 2 of 2
if it is one:
bye Fishtown
1 REPLY 1
