Accessing menus from TV itself
1 ANTWORT 1
Cinders
Nachricht 1 von 2
1.057 Aufrufe
Nachricht 1 von 2
1.057 Aufrufe
Model number MD 20143
Hi everyone. We've recently acquired a Logix TV and when we press the buttons at the side of the TV (note remote) and access the menus, we can't find out how to select the function we want.
The manual doesn't say.
Which button do I press please?
Thank you!
Tags (1)
1 ANTWORT 1
Nachricht 2 von 2
1.050 Aufrufe
Nachricht 2 von 2
1.050 Aufrufe
@Cinders
May be you have the quick version of the manual. Here is the complete manual, to be dwnladed.
--> https://drive.google.com/file/d/1BCtjsQ1aqsjIGqlsNEgtKcOgmyGTWp0z/view?usp=sharing
Inside you will find the  informtions you need. Check Page 7 first - then check page 19
If you press the menu button,  you can scroll through the menu with the up/down buttons,
But it would be more easy to make use of the remote control-
Cheers, daddle
1 ANTWORT 1
