Medion lifetab p8314
31 RÉPONSES 31
fioor
Message 1 sur 32
14 299 Visites
Message 1 sur 32
14 299 Visites
Hello! I have a trouble with installing update 2 on this tablet! Sorry for my band english! Here's photo of error!
https://postimg.org/image/nv0yarc7r/
31 RÉPONSES 31
fioor
Message 11 sur 32
6 311 Visites
Message 11 sur 32
6 311 Visites
Hi @RS13,
Hello,thank you for fast answer, i will wait for results! I hote it will be good results)
Luke
Community Manager
Message 12 sur 32
6 287 Visites
Message 12 sur 32
6 287 Visites
Hi @fioor,
Our Android Team just sent us the relevant infos.
Here is the correct update sequence:
MP: 0da85c2.0724.1420
OTA Update #1: 0da85c2.1009.1359
OTA Update #2: 160307.0240.a176256
According to your screenshot, your device is on the "MP" stage, and the error-text says
that it`s demanding OTA #1 first. Therefore we assume that you are trying to update from
"MP" to OTA #2 without installing OTA #1 first. This will not work.
Our Android Team also provided a detailed PDF-Manual how to install both OTA #1 and #2
in English with Russian screenshots. I`ll send it to you via PN in some minutes.
Greetings,
Luke
fioor
Message 13 sur 32
6 277 Visites
Message 13 sur 32
6 277 Visites
Hi
I dont receive ota 1, i always receive ota 2! Maybe if you cant send me ota 1 and ota 2 via email, i can solve this problem! I also tried to factory reset, wipe cache partition, and also i receive ota 2,not ota 1!
Luke
Community Manager
Message 14 sur 32
6 267 Visites
Message 14 sur 32
6 267 Visites
Hi again @fioor,
According to the picture showing the error message , your device is still at MP stage. This does not fit together.
Our Android-Team has tested the OTA chain from MP to OTA #1 and OTA#2 successfully twice, so they cannot reproduce the issue here.
Perhaps you could also provide a screenshot of the system settings?
Please go to
“System -> Settings -> About your device”
and take a screenshot with the “Build Number” visible in it.
Next, on the same screen, please press “Status”, scroll down a little and take another screenshot that shows the serial number of your device.
Thanks for your cooperation,
Luke
fioor
Message 15 sur 32
6 259 Visites
Message 15 sur 32
6 259 Visites
Message 16 sur 32
6 241 Visites
Message 16 sur 32
6 241 Visites
@fioor
Did you make use of xposed and restored a backup? This probably could explain the difference in  release keys shown in recovery and in system settings.
On the other hand, an error in /cache/recovery/block map happened more often whilest updating this tablet, so I guess it should be sent into service to get it reflashed with the complete firmware.
Regards, daddle
fioor
Message 17 sur 32
6 239 Visites
Message 17 sur 32
6 239 Visites
I dont install xpossed, bought this tablet with this firmware, maybe i can install stock firmware by myself! I found stock firmware on offsite, can i install that firmware?
Message 18 sur 32
6 232 Visites
Message 18 sur 32
6 232 Visites
Hi @fioor, is  it a second hand tablet?
Where did you find a original firmware for this tablet? I can not say anything about it because I do not know this "special" firmware. Maybe you could send me the link for it by private notice?
fioor
Message 19 sur 32
6 154 Visites
Message 19 sur 32
6 154 Visites
Hi @Luke,
Do you have any solutions about my problem? Maybe your android team can send me stock firmware or update 1?
Luke
Community Manager
Message 20 sur 32
6 109 Visites
Message 20 sur 32
6 109 Visites
Hello @fioor,
Did you see the last answer sent by @daddle ?
31 RÉPONSES 31
