04.08.2020 17:02
04.08.2020 17:02
Hi all,
I recently got this tablet (E10513), that came with an exercise bike, with pre-loaded software that only allows the bike exercise app to run. The bike has broken down, so looking for another use of this tablet.With that, I have tried flashing the OS to the base version it comes with.
I have tried going through the steps listed here http://download.medion.com/downloads/software/FlashMTK-EN.pdf but I keep getting the BROM error listed in troubleshooting of the above document. Of potential importance, the MSN number of the tablet is 4006 5764, which I cannot find when looking up. I have been using the MSN 3002 3584 as it seems like the same device. All the relevant downloads were gotten here: https://www.medion.com/gb/service/product-detail/30023584?fromTopicsPage=true . Does anyone have any ideas on how to get this back to running just the basic android 7.0 without the bike add-ons?
Thanks
04.08.2020 17:24
04.08.2020 17:24
Hi @branch150 and welcome to the Forum!
For performing a factory settings reset on your tablet, you must:
Regards,
Gehringer
04.08.2020 17:30
04.08.2020 17:30
Hi Gehringer,
I have tried factory resetting it earlier, but this does not cause the bike software to go away. After factory reset, it still only runs the exercise bike application and can do nothing else. That is why I have tried resorting to flashing/recovering the original operating system on a E10315.
Thanks for your response,
branch150
04.08.2020 17:45
04.08.2020 17:45
Hi @branch150 ,
probably the tablet came with a tailored OS version.
You may need to install a vanilla version of Android and for doing so I recommend you to look for a specialized Android forum.
Regards,
Gehringer
04.08.2020 17:49
26.02.2023 20:29
26.02.2023 20:29
Hi,
I'm in the same situation as you, and want to install some kind of stock Android on this tablet that came with the bike. Did you ever succeed in doing so?
Thanks!
