on 18.02.2024 14:44
on 18.02.2024 14:44
Hi there
Is it possible to get a new bios for the Medion X6805 - MD 61140 Erazer laptop MSN - 30025007?
Current bios is N.1.03
For some reason the boot order keeps changing to default.
Thanks in advance!!
on 22.02.2024 12:49
on 22.02.2024 12:49
Hi @Darious_M ,
here´s another shot, I included the files you need to update the "bios" via the device manager.
+++Installation+++
1.Download the Bios Update
2. Unzip the downloaded fil 00_Bios_x680x_fw.zip to a folder on your hard drive
3. Open up the dev manager, go to Firmware, System Firmware and choose the option "Update driver" (see pic)
4. Refer to the folder wher you unzipped the downloaded file and the update process will start immediately.
Feedback very appreciated
Cheers
