Bios update!!! motherboard - Z370h4-em (370h4w0x.109)
3 REPLIES 3
Lolikoov
Message 1 of 4
Message 1 of 4
Hello everybody
My motherboard does not have the correct version of the BIOS firmware
I found the correct file on the site but cannot download it
Please share the firmware file
PC MD34060 / 2528
Motherboard - Z370h4-em
Required firmware file is 370h4w0x.109
MSN - 10022247
Here is the firmware file
when you click Download:
Tags (3)
3 REPLIES 3
Gehringer
Retired
Message 2 of 4
Message 2 of 4
Hi @Lolikoov
you can upload your BIOS using the Device Manager. It is indeed the best option for doing so.
Just go to the Device Manager, Left click on the arrow besides Firmware and then right click on System Firmware and select update driver.
Regards,
Gehringer
Lolikoov
Message 3 of 4
Message 3 of 4
hello @Gehringer
unfortunately Bios cannot be updated this way
You may not understand me
in order to flash the BIOS, special programs and a firmware file are used
Medion site is down
I wrote in support to get it restored, but it doesn't work yet
Gehringer
Retired
Message 4 of 4
Message 4 of 4
Hi @Lolikoov ,
the support team should contact you shortly, then.
Please let us know if their solution solved the issue.
Regards,
Gehringer
3 REPLIES 3
