Connecting BT Light Bulb Speaker MD43510 USA to Amazon Alexa
1 REPLY 1
cskamil
Message 1 of 2
Message 1 of 2
I am not sure if here is the right place to ask. I am not living in Germany. I bought this bulb from Aldi USA. It is working with my mobile and I want to connect it to my echo dot device.
I am trying to enable the skill below is the link:
https://www.amazon.com/MEDION-AG-Medion-Smart-Home/dp/B0727RNQ67/ref=sr_1_2?keywords=medion&qid=1575...
It asks me an account to be opened at Medion Smart Home website. I have created the account but I am not sure if the webpage I found is correct. I am trying to use my credentials to link my account to alexa skill, it does not allow me to login. You can see the screenshot below.
So first of all, can I connect BT Light Bulb Speaker MD43510 USA to Amazon Alexa? If yes, how.
Thanks,
Kamil
1 ACCEPTED SOLUTION
Gehringer
Retired
Message 2 of 2
Message 2 of 2
Hi @cskamil and welcome to the forum!
Unfortunately your bulb is not compatible with Alexa.
Regards,
Gehringer
1 REPLY 1
Gehringer
Retired
Message 2 of 2
Message 2 of 2
Regards,
Gehringer
1 REPLY 1
