Medion Akoya s2217 MD99525 video driver
10 ANTWOORDEN 10
GabrielMC
Bericht 1 van 11
10.566 Weergaven
Bericht 1 van 11
10.566 Weergaven
I recently installed windows 10 2004 version and dont recognize the video driver . Where I can find the video driver for that windows version ? Or what windows version I need install for its better performance , I need help fast please. 🙏
Tags (2)
10 ANTWOORDEN 10
Gehringer
Retired
Bericht 2 van 11
9.149 Weergaven
Bericht 2 van 11
9.149 Weergaven
Hi @GabrielMC ,
if you have Windows 10 you can upload the driver directly from the device manager.
Alternatively, you can check for drivers at video card manufacturer website.
Please find more information on this post here
Regards,
Gehringer
Luke
Community Manager
Bericht 3 van 11
9.146 Weergaven
Bericht 3 van 11
9.146 Weergaven
Hello @GabrielMC & @Gehringer,
The GPU is an Intel HD Graphics, a driver-tool can be found at their website.
Cheers,
Luke
GabrielMC
Bericht 4 van 11
9.128 Weergaven
Bericht 4 van 11
9.128 Weergaven
Sorry , it doesn't work , it's says : not supported driver or software updates are available for your system . @Luke @Gehringer
GabrielMC
Bericht 5 van 11
9.124 Weergaven
Bericht 5 van 11
9.124 Weergaven
This is how looks like
GabrielMC
Bericht 6 van 11
9.120 Weergaven
Bericht 6 van 11
9.120 Weergaven
I try everything and it doesn't work and is not only video , same as audio , I can't use my hdmi port. Can u send me a good driver for mail , whatsapp , mega . The msn is 30019439
Luke
Community Manager
Bericht 7 van 11
9.071 Weergaven
Bericht 7 van 11
9.071 Weergaven
Hello @GabrielMC,
That`s indeed strange.
Please go to Device Manager -> Audio/Video & Graphics Adapters and expand the relevant sections. Then check if there is a listed driver or not.
Right click on each driver listed and select the "update driver" option.
Please keep us informed,
Luke
GabrielMC
Bericht 8 van 11
8.992 Weergaven
Bericht 8 van 11
8.992 Weergaven
It doesn't work , the controller's doesn't found the video driver , I don't know how to fix , it's any place where I can found the originals drivers ???
Bericht 9 van 11
8.980 Weergaven
Bericht 9 van 11
8.980 Weergaven
Hi @GabrielMC ,
I hope it helps:
http://www1.medion.de/downloads/?op=search&lang=uk&type=TEXT&param=s221x&imageField.x=0&imageField.y...
bye Fishtown
CarlosVal
Visitor
Bericht 10 van 11
8.962 Weergaven
Bericht 10 van 11
8.962 Weergaven
Hello,
I have uploaded original drivers. Try "chipset" and "win8" instaler. Then "sound" "win8" "PG033" "setup.exe" and reboot,
xxxxxxxxxxxxxxxxxx
Hope it helps,
Carlos
EDIT:
External links removed due to possible violation of our Terms of Use,
points 6.2, 6.3, 6.4, 6.7 & 13.
10 ANTWOORDEN 10
