Medion Akoya s2217 MD99525 video driver
10 RÉPONSES 10
GabrielMC
Message 1 sur 11
10 588 Visites
Message 1 sur 11
10 588 Visites
I recently installed windows 10 2004 version and dont recognize the video driver . Where I can find the video driver for that windows version ? Or what windows version I need install for its better performance , I need help fast please. 🙏
Balises (2)
10 RÉPONSES 10
Gehringer
Retired
Message 2 sur 11
9 174 Visites
Message 2 sur 11
9 174 Visites
Hi @GabrielMC ,
if you have Windows 10 you can upload the driver directly from the device manager.
Alternatively, you can check for drivers at video card manufacturer website.
Please find more information on this post here
Regards,
Gehringer
Luke
Community Manager
Message 3 sur 11
9 171 Visites
Message 3 sur 11
9 171 Visites
Hello @GabrielMC & @Gehringer,
The GPU is an Intel HD Graphics, a driver-tool can be found at their website.
Cheers,
Luke
GabrielMC
Message 4 sur 11
9 153 Visites
Message 4 sur 11
9 153 Visites
Sorry , it doesn't work , it's says : not supported driver or software updates are available for your system . @Luke @Gehringer
GabrielMC
Message 5 sur 11
9 149 Visites
Message 5 sur 11
9 149 Visites
This is how looks like
GabrielMC
Message 6 sur 11
9 145 Visites
Message 6 sur 11
9 145 Visites
I try everything and it doesn't work and is not only video , same as audio , I can't use my hdmi port. Can u send me a good driver for mail , whatsapp , mega . The msn is 30019439
Luke
Community Manager
Message 7 sur 11
9 096 Visites
Message 7 sur 11
9 096 Visites
Hello @GabrielMC,
That`s indeed strange.
Please go to Device Manager -> Audio/Video & Graphics Adapters and expand the relevant sections. Then check if there is a listed driver or not.
Right click on each driver listed and select the "update driver" option.
Please keep us informed,
Luke
GabrielMC
Message 8 sur 11
9 017 Visites
Message 8 sur 11
9 017 Visites
It doesn't work , the controller's doesn't found the video driver , I don't know how to fix , it's any place where I can found the originals drivers ???
Message 9 sur 11
9 005 Visites
Message 9 sur 11
9 005 Visites
Hi @GabrielMC ,
I hope it helps:
http://www1.medion.de/downloads/?op=search&lang=uk&type=TEXT&param=s221x&imageField.x=0&imageField.y...
bye Fishtown
CarlosVal
Visitor
Message 10 sur 11
8 983 Visites
Message 10 sur 11
8 983 Visites
Hello,
I have uploaded original drivers. Try "chipset" and "win8" instaler. Then "sound" "win8" "PG033" "setup.exe" and reboot,
xxxxxxxxxxxxxxxxxx
Hope it helps,
Carlos
EDIT:
External links removed due to possible violation of our Terms of Use,
points 6.2, 6.3, 6.4, 6.7 & 13.
10 RÉPONSES 10
