le 02.06.2022 23:17
le 02.06.2022 23:17
Hi,
My TV MEDION LIFE X15061 (MD 31541) did an automatic software update and now it won't start anymore. The blue light keeps on flashing more than 24h after the initial update. Is there a way to get the old version back (without starting the TV since it does not)? Or can I try to redo the update via a USB stick?
Thank you very much in advance,
le 03.06.2022 20:33
le 03.06.2022 20:33
Hi @ar1884 and welcome
Try this if your device is in the list.
X15061/ MD31541/ MSN ??
https://community.medion.com/t5/kb/en/ta-p/131092
good luck, Fishtown
le 08.06.2022 14:45
le 08.06.2022 14:45
Thank you for your reply. My TV is indeed in the list, but I tried to update it with a usb stick using that softare, but it did not work...
le 09.06.2022 11:28
le 09.06.2022 11:28
Hello @ar1884
I'm about to send you a software for your TV via private message. After that, the TV should work again.
23.07.2023 11:19 - modifié 23.07.2023 11:19
le 24.07.2023 10:24
le 24.07.2023 10:24
Hello @Slli
yes it is possible. I will send you the same message.
