MEDION LIFE X15061 (MD 31541)
5 ANTWORTEN 5
ar1884
Nachricht 1 von 6
2.904 Aufrufe
Nachricht 1 von 6
2.904 Aufrufe
Hi,
My TV MEDION LIFE X15061 (MD 31541) did an automatic software update and now it won't start anymore. The blue light keeps on flashing more than 24h after the initial update. Is there a way to get the old version back (without starting the TV since it does not)? Or can I try to redo the update via a USB stick?
Thank you very much in advance,
5 ANTWORTEN 5
Nachricht 2 von 6
2.897 Aufrufe
Nachricht 2 von 6
2.897 Aufrufe
Hi @ar1884 and welcome
Try this if your device is in the list.
X15061/ MD31541/ MSN ??
https://community.medion.com/t5/kb/en/ta-p/131092
good luck, Fishtown
ar1884
Nachricht 3 von 6
2.866 Aufrufe
Nachricht 3 von 6
2.866 Aufrufe
Thank you for your reply. My TV is indeed in the list, but I tried to update it with a usb stick using that softare, but it did not work...
Daniel
Nachricht 4 von 6
2.845 Aufrufe
Nachricht 4 von 6
2.845 Aufrufe
Hello @ar1884
I'm about to send you a software for your TV via private message. After that, the TV should work again.
VG,
Daniel
Slli
Participant
Nachricht 5 von 6
1.830 Aufrufe
Nachricht 5 von 6
1.830 Aufrufe
Is it possible that I receive this software as well? I have a Medion MD30630, blue blinking light…. @Daniel
Daniel
Nachricht 6 von 6
1.822 Aufrufe
Nachricht 6 von 6
1.822 Aufrufe
Hello @Slli
yes it is possible. I will send you the same message.
VG,
Daniel
5 ANTWORTEN 5
