on 30.04.2022 10:45
on 30.04.2022 10:45
The laptop does not have sound I cant find the right drivers for the sound I connected the laptop with hdmi to the tv and jt had sound and right when i took out the hdmi it didnt had sound What are the correct drivers i have to install?
on 01.05.2022 22:55
on 01.05.2022 22:55
Hello @echida and welcome
Drivers can be found on drive D:drivers
or here: https://www.medion.com/de/service/product-detail/30018189
are the speakers turned off? Fn+F10
do headphones work?
bye Fishtown
23.11.2022 07:28 - edited 24.11.2022 04:38
@echida wrote:The laptop does not have sound I cant find the right drivers for the sound I connected the laptop with hdmi to the tv and jt had sound and right when i took out the hdmi it didnt had sound What are the correct drivers i have to install? PeopleNet Fleet Manager Login
Download drivers for sound card for Medion Akoya E7416 laptop (Windows 10 x64), or download DriverPack Solution software for driver update.
Thanks,
M25Jeter
on 23.11.2022 08:11
on 23.11.2022 08:11
Hello @M25Jeter, and welcome to the community.
If you have the same problem as the thread creator then I would recommend you to install the sound card driver first.
Greetings,
EastClintwood
on 24.11.2022 04:37
on 24.11.2022 04:37
@EastClintwood wrote:Hello @M25Jeter, and welcome to the community.
Greetings,
EastClintwood
Hello, @EastClintwood
Thanks for sharing my friends have same problem now your provide solution is work for him thank you very much..
Thanks,
M25Jeter
